Antenna and range
Mar 29, 2005 5 Replies
Jump to replies (5)
I have a new dsl Linksys wireless setup and are getting only low connects. Are the Antenna boosters any good? My system is a WRT54GS at my base desktop connected wireless to a desktop with a WUSB54GS less than 50 feet away. The base(mine) works great, the other (my wife's) is consistently loosing connection. Any suggestions appreciated. Ross
Your cordless phone can interfere with the wireless network signal. If you have a cordless phone, check to see if it is communicating at 2.4 gigahertz. It will likely have either 9, 24 or 58 in the model number. 24 would indicate 2.4 gigahertz.
EZ-10 worked for me. Free.
Also try :
whatever pigtail you need.
That omni is great!! Used one at a motel. We thought we would need repeaters, but by adding this one item, all worked GREAT!
