access wirelessly the desktop from laptop
Apr 03, 2005 45 Replies
Taking a moment's reflection, Ritter197 mused: | | What do you mean with the statement "have the UltraVNC running"? | What do you want me to do?
I'm sorry, I don't see where the words "have the UltraVNC running" appear in the text you quoted. Since I only mention UltraVNC in the last paragraph (recommending you take a look at it), perhaps you meant to reply to, and quote, someone else's message.
Taking a moment's reflection, Mark McIntyre mused: | | assuming 192.168.0.101is the right address either | a) you dont' have the VNC server running at the far end or
He would receive a "server not found" message ...
| b) your firewall at the far end is blocking it or
Possibly the XP firewall ...
| c) you configured the server to reject incoming connections from the | laptop
VNC cannot block incoming connections from specific IPs ...
True. But its easier to simply let it install itself as a service and not worry further, especially in the case of this sadly confused end-user....
you may be right. Since I have my network set up right I never encounter this problem!!
I meant the remote computer. I tend to use VNC to control servers.
Hi and Thanks to all who helped.
I got, with all your patient help, everything working.
Best regards to you all
