skype phone?
Jan 06, 2005 7 Replies
Most relevant reply
Pepperoni
The SIP handset mutes your speakers when in use, inexpensive and good voice quality. 's a USB handset that bypasses your sound card for excellent digital voice. 's branded "Glophone", but I have it in use both with SJPhone and XTen for several networks. Perhaps the best…
skype phone? open original image
With Skype, is there any phone that connects to the audio port on my computer and then works just like a regular phone?
- JB
Here's a USB handset that bypasses your sound card for excellent digital voice.
's branded "Glophone", but I have it in use both with SJPhone and XTen for several networks. Perhaps the best solution for net phone use.
I own both of these units. I now use the USB phone because of the handset dialer and better voice quality. The USB handset does not use your pc soundcard to function.
Where are you located..? In the UK Maplins sell a USB phone that works with Skype.
Ivor
JB schrieb:
There is a SIEMENS USB-dadpter which allows you to use your regular phone. The price in Germany is 100 ¤.
Or there's the Cyberphone K (note the K suffix) from
- you need the *orange* colour-coded one for Skype. Don't have prices to hand but mine was around £30 here in the UK.
Ivor
"Ivor Jones" wrote > > There is a SIEMENS USB-dadpter which allows you to use your regular
Is the Siemens M34USB available here in the UK or has anyone got any experience of using one?
Sidk
I've been collecting links to all the "Skype phones" that I can find. You can check them out at
I also wrote a an "article", kind of summarizing all the different Skype phones that I've discovered
Good Luck, Philip
