wifi phone
Jul 30, 2006 3 Replies
Jump to replies (3)
Hi all,
has anyone come across any reviews of this device actually in use ?
I am tempted but although it appears to be released I have googled and can not find reviews of what people will think it is like ?
surely a phone connected via wifi would need a serious battery ?
David
If you only want to use it at home then there are other options - such as the ability to connect a DECT set to Skype..
This looks interesting, I do not really understand dect etc but the review
12 appears to simply be a box that would allow std calls and skype calls to be sent to my home phone ?
my only slight fear is the rest of the family getting used to the * use etc.
I am tempted by the linksys skype phone which is much more affordable than the wifi unit.
David
They are just digital cordless phones.
I believe it's just a kind of switch. It automatically connects the phone (or for example a cordless phone system base station) to the regular phone line and the USB cable to your computer (eg skype). When you dial the * routes the call accordingly - either out on the phone line or via your PC and skype.
With this type of device check what happens when there is a power cut - eg can you still make emergency calls on the regular phone line.
