Sipura SPA-2100 Dial Plan
Feb 21, 2005 8 Replies
Jump to replies (8)
This seems to be the bit you need to set up Looks fairly normal and far simpler that the Cisco ATA
Subsequence Substitution: A subsequence of keys (possibly empty) can be automatically replaced with a different subsequence using an angle bracket notation: ?'. So, for example, "xxxxxxx" would match "85551212" and transmit "16505551212".
so in your case it would be
( 0 xxxx xxxxxx |00 xxxxxx xxxxxx | xxxxxx )
Or thats how it reads and how I woul expect it to work, As the first entry says anything starting 0 with 10 digits to follow send as dialed same for 00 but everything else dial 01247 before it. if that doesnt substitute correctly you may have to do xxxxx etc for 2 to 8
Good luck
Ian
Anyone any idea how I can write a dial plan that simply adds 01247 to any 6- digit number dialled but leaves numbers starting with 0 to be dialled as entered?
Thanks.
I've had a look in the user manual for my SPA-2000 which I assume would work in the same way, but can't figure it out..! If you do find a solution, I'll be interested as I'd like to do something similar.
Ivor
Ivor Jones wrote: || The Cable Guy wrote: ||| Anyone any idea how I can write a dial plan that simply adds 01247 ||| to any 6- digit number dialled but leaves numbers starting with 0 ||| to be dialled as entered? ||| ||| Thanks. || || I've had a look in the user manual for my SPA-2000 which I assume || would work in the same way, but can't figure it out..! If you do || find a solution, I'll be interested as I'd like to do something || similar. || || Ivor
There's quite a useful forum here
with a whole section dedicated to Sipura users.
I'll let you know if I get to grips with it.
([2-9]xxxxxS0|0[1-8]xxxxxxxxxS0|001[2-9]xx[2-9]xxxxxxS0|00[2-9]xxxxx)
The above is what I've ended up with. SO is the send now command. I've not tested any international calls but the UK part works a treat.
Thanks for your input
It works.
I've not tested the last 2 elements yet - USA 001[2-9} nor Rest of World
00[2-9] - local numbers I can now dial the six-digit number, the second element allows 11 digit numbers starting 01 to 09 to be dialed. Shorter numbers(BT's cust serv no. 0800800150) still go through but with a 3 second delay - unless I press the # key at the end of the number when it dials immediately.
[snip]
Can you dial 7-digit SIP numbers directly..?
Ivor
Ivor Jones wrote: || The Cable Guy wrote: || || [snip] || ||| ([2-9]xxxxxS0|0[1-8]xxxxxxxxxS0|001[2-9]xx[2-9]xxxxxxS0|00[2-9]xxxxx) ||| ||| It works. ||| ||| I've not tested the last 2 elements yet - USA 001[2-9} nor Rest of ||| World 00[2-9] - local numbers I can now dial the six-digit number, ||| the second element allows 11 digit numbers starting 01 to 09 to be ||| dialed. Shorter numbers(BT's cust serv no. 0800800150) still go ||| through but with a 3 second delay - unless I press the # key at the ||| end of the number when it dials immediately. || || Can you dial 7-digit SIP numbers directly..? || || Ivor
I don't know anyone with a sip number - I guess the answer with the above plan would be "No" because as soon as the sixth digit were dialled, 01247 would be added to the beginning. I'll do some more research..........
Are you aware of any SIP test numbers I could try?
I guess |[1-9]xxxxxxS0 would allow for that - I could be completely wrong, unless you've got a 7 digit SIP test number I could try.
