Also, check out...
J
Jonathan Roberts
's forums dslreports.com Voip forum
Also, check out...
Alright. I'll plug it into a hub with a test client to hit it with a browser.
SER looks it's for bigger setups than I need. I don't know yet about VoIP to really understand the pro's and con's of Asterisk vs. sipX.
Added to my shopping list :-) Thx.
?.1=2
Ever wish you could use your favorite single-line telephone, answering machine, or PC Modem on TWO phone lines??. Automatically?
OR
How about joining your VOIP port and the plain old (PSTN) telephone jack into a single handset?
OR
How about joining TWO VOIP ports into a single handset, answering machine, or PC Modem?
USE a CLT to join a card card acceptor and your single line telephone as well!
OR
see if anybody picks-up, on another line trunk, after you are already in a call??? A visual real-time security feedback feature!
THEN...........................................
Combine-A-Line (CLT) allows two separate calls from two different lines to be directed to your single line telephone equipment or PC. Centralizing and PROTECTING (SURGE PROTECTION INSIDE) your communication equipment for your home office or for the family
