Linksys PAP2 hack?
Feb 25, 2005 5 Replies
mazilo
The PAP2 usually comes preset with the provider's IP, and seeks it Who's your PAP2 provider, i.e Vonage? Can the PAP2 be hacked to seek another Asterix box for example? I'd be has (SIP?) I haven't seen one hacked, yet. I'm also not sure if the firmware of the PAP2 is located in…
The PAP2 usually comes preset with the provider's IP, and seeks it itself. Only after the provider gives its connection, does the dial tone appear on the PAP2.
Can the PAP2 be hacked to seek another Asterix box for example? I'd be interested in a setup where I have the two POTS ports of the PAP2 available, and I could dial from one to another. I'm sure the PAP2 has no pbx capabilities, but would be nice to get it to talk to a linux-based pbx at home.... unless its communication protocol (SIP?) is too proprietary.
I'm also not sure if the firmware of the PAP2 is located in a different spot from the configuration, or is everything configured, compiled and burned? If the config is in a different place, making it point elsewhere should be trivial..
If it speaks standards-based protocols, I could even fake the IP it seeks, pointing to a local asterix box for the job.
Any thoughts?
This also allows me to roll out my own VOIP joint... or at least skype-type joint where people can use their standard phones + PAP2, without the use of a computer. Legal issues in reconfiguring the PAP2 if at all possible?
Why not just get a Sipura box that you don't need to hack????
Mike Schumann
be
has
(SIP?)
it
I hear from other forums that resetting the PAP2 to its factory
original will certainly remove the lock; however, during the process
of resetting, it will ask you the password if the PAP2 has been
registered to some provider.
AFAIK, PA2 along with most ATA devices on the market are SIP
compliance; thus, it speaks some standard-base protocols.
PAP2
How would you do that since Skype is not SIP compliance?
Ive been told you can sniff out the connection stream for the Pap2 and the other linksys vonage routers.
No firmwares have been posted to convert to the NA models so far as i know.
I personaly would like to make my asterisk box the vonage ATA device.... and to use my Linksys rtp "vonage" router as a phone adaptor for my network.
I may have to convert to another phone providor that is more asterisk friendly.... but i would still have this linksys gear .... unusable.
It is an idea. Why doesnt someone call up vonage with their pap2 device
(using the old firmware) and have vonage "flag" an update to their
device. The way i look at it is this. If vonage can force feed a
firmware update to the boxes, why cant we? If they flag one of the
boxes, and we have ethercap running, we capture the traffic, we analyse
it, and most likely we get the magical admin password to the pap2. If we
dont get the admin password atleast we figure out how they feed firmware
and we can copy the firmware the same way (through faked dns entries and
such)
Its a valid idea, and i have a VIRGIN pap2 to try your ideas on. (i am
currently trying to brute force the username and password which is
frankly impossible even at 1000 attempts per second, it will take
1million years, no joking, to force the password)
device (using the old firmware) and have vonage "flag" an update to
their device. The way i look at it is this. If vonage can force feed
a firmware update to the boxes, why cant we? If they flag one of the
analyse it, and most likely we get the magical admin password to the
pap2. If we dont get the admin password atleast we figure out how
they feed firmware and we can copy the firmware the same way (through
faked dns entries and such)
