High latency connection - sugestions 4 VoIP service(s)/settings??
Mar 11, 2006 2 Replies
Zeng
jbr, You should look into what they're doing when running VoIP via VSATs. I don't how they address the latency but I think there's a few installations out there. Your delays sound like they'd fall into that category. BTW, who makes the 450 equipment that you're using? Zeng
Hi All,
I'm using a wireless CDMA450 connection, with latency around 500 ms. Stable bandwith is limited to 153 Kbps
Given this conditions,:
1) which services could possibly be better for me, and
2) could any custom settings on the softphone improve my calls?
TIA, jbr
I don't know, and I don't think the company would tell me about those details
I'm not sure about the manufacturer, (althoug apparently Kyocera), I can only identify the model: Telemodem Z010.
The provider is Zapp:
I'm in Portugal.
Regards, jbr
