Weird setup for a phone jack
Jul 02, 2006 6 Replies
Jump to replies (6)
Hi, I was wondering if someone could explain this weird setup for a phone jack in one of my bedrooms. The wall plate has what looks like quad wire coming out from behind it (pinched between the drywall and the edge of the plate) and this cable in turn goes to a wall wart plugged into an outlet with two screw terminals on the underside. One screw has the red wire, the other the green wire. Is this some sort of alarm circuit? My house was built in 1976, FWIW.
Alarm maybe, but doubtful. More likely, the power supply for an early version of a trim line or princess phone.
The first versions of those phones wouldn't operate on phone line voltage. They needed their own separate power supply to light the buttons, etc.
Take care, Rich
God bless the USA
Yep - I completely forgot that the Trimline I have in my posession is a
1982 vintage. It had the green LED lighting that ran off line current. Problem is I modified this phone to use it with Skype. Normal plan calls for one 9V battery but I had to parallel two 9V units for the extra current.
If you don't have the phone, it's a good idea to disconnect the wall wart.. there was a certain model that had a tendancy to overheat, and could cause fires.
I'm guessing that it's grey, made by western electric, and about
1.5"w X 2.5"h X 1.5"d (from memory.) rectangular, with straight sides, and rounded corners and edges. I seem to recall that the guts were potted.
I also saw a bunch that were the same description as you give, except they were pink (guess they went on phones that were used to call a Mary Kay rep? ;-). Two straight slot screws for the voltage terminals, slightly recessed.
Take care, Rich
God bless the USA
