Re: Ping Between PC Through PABX
Jun 20, 2005 0 Replies
Hi there,
> I'm trying to connect two computer using PABX. So the PABX will be act
> like a hub. This is the diagram:
> [Computer 1] -> [Modem] -> [PABX] the PABX after doing dial up. But why can't I ping between those
> computer?
> Both computer has been connected to the pabx, but they just can't
> ping/communicate each other. Is there anything wrong here? It is
> possible to do this, right?
> Thank you so much for the response.
Not clear exactly how you are doing this. I assume one computer is dialing the other thru the PBX? And you are using RAS? How are IP addresses being assigned?
