Re: Ping Between PC Through PABX
Jun 20, 2005 0 Replies
Both computer has been connected to the pabx, but they just can't
> ping/communicate each other.
Does the PABX have modems of its own? Or is it just providing a connection between the two computers? If the latter, when you run a term program (such as hyperterm) do you see 'RING' at the recipient computer? Does it answer when given the appropriate AT command? (Assuming it uses the Hayes command set.) Do they establish a connection? (If you get garbage, make sure speed, parity, word length settings are the same for both computers.)
Try setting a very low speed (e.g. 1200 bps) for a start. Don't use a speed >28.8K.
