Iwatsu Omega IV 616
Aug 09, 2005 0 Replies
Hi! I have just recently picked up an Iwatsu Omega IV 616 system. The system was removed from a working environment, or so I was told.
I am now setting it up. Unfortunately, I seem to be having problems getting the extension phones to operate. When hooked up, they simply keep clicking, even without the handset lifted. There is no dialtone or anything.
As of now, I have tried different RJ-21 ends on this thing, but I seem to keep running into brick walls.
I believe that this is a problem with the ends, the key system unit hardware, or the software on the system. I cannot further isolate this problem, though. I do know, however, that it is not the phones -- I have tested several to no avail.
Anyone have any ideas?
Thanks!
P.S. Some extensions did 'work,' but then mysteriously went bad.
