Wireless CCTV
Mar 16, 2008 5 Replies
Jump to replies (5)
I have to help a friend with a small outdoor camera job. It is a simple two cameras application. Usually I use Verint (Nextiva) S1100 for wireless. However this is out of budget for this guys application. I was thinking of Trango or Azalea instead. Anyone has any particular likes in models or brands for this kind of job?
used VideoComm with great success in the past.
Dang, Trango ain't cheap and you are looking them as an ALTERNATIVE? How much does the stuff you usually use cost?
A VERINT SYSTEMS PRICE AND SELECTION GUIDE These are LIST price, not dealer. August 2, 2007. S1100w-12VDC-49 S1100w Multi-band Transmitter with 13 dBi, 4.9 GHz antenna (12V DC input). North America $2,075 S1100w-24VAC-49 S1100w Multi-band Transmitter with integrated 13 dBi, 4.9 GHz antenna (24V AC). North America $2,125 S1100w-12VDC-5x Multi-band Wireless Video Transmitter with integrated 13dBi,
5.15-5.85 GHz antenna (12VDC input) $1,650 S1100w-24VAC-5x Multi-band Wireless Video Transmitter with integrated 13dBi, 5.15-5.85 GHz antenna (24VAC input) $1,700 S1100w-12VDC-24 Multi-band Wireless Video Transmitter with 8.5dBi, 2.4 GHz antenna (12VDC input) $1,650 S1100w-24VAC-24 Multi-band Wireless Video Transmitter with 8.5dBi, 2.4 GHz antenna (24VAC input) $1,700 Nextiva S1100w Wireless Video Transmitters do not include power supplies unless specifically stated. PS2440 Power supply 110V AC to 24V AC with 40 VA for one (1) 24VAC wireless device $30 PS2440-UK Power supply; 220V IN; 24V AC OUT; 1.5A; 50Hz; DESKTOP (BUILT-IN POWER CORD); United Kingdom; CE, GS; ROHS $30 PS2440-EU Power supply; 220V IN; 24V AC OUT; 1.5A; 50Hz; DESKTOP (BUILT-IN POWER CORD); Europe; CE, GS; ROHS $30 PS12 Power supply 100-240V AC to 12V DC with 1.25 A for one (1) 12VDC wireless device $21 CAB8P 3 meter (10-foot) cable assembly for audio and alarms $70 CAB9P Spare 3 meter (10-foot) 9-pin cable assembly for video, data, and power $80 PMBR Replacement pole mount brackets with adjustable stainless steel straps for S1100w $25 S3100-49 4.9 GHz Wireless Access Point (48V DC input) comes with power-over-Ethernet injector, 25-meter outdoor Ethernet cable, wall mount, pole mount brackets (antenna not included) $1,775 S3100-5x Outdoor 5.3 or 5.8GHz Wireless Ethernet Bridge (48VDC input) comes with Power over Ethernet/PoE injector, 25- meter outdoor Ethernet cable, wall mount, pole mount brackets (antenna not included) $1,350 S3100-24 Outdoor 2.4GHz Wireless Ethernet Bridge (48VDC input) with Power over Ethernet/PoE injector, 25-meter outdoor Ethernet cable, wall mount, pole mount brackets (antenna not included) $1,350 S3100-RP-49 4.9 GHz wireless Ethernet repeater (24V AC input) with 1 meter outdoor Ethernet cable, wall-mount and polemount brackets (2 antennas not included) $3,225 S3100-RP-5x Outdoor 5.3 or 5.8GHz Wireless Ethernet Repeater (24VAC input) with 1 meter outdoor Ethernet cable, wallmount and pole-mount brackets (2 antennas not $2,400 S3100-RP-24 Outdoor 2.4GHz Wireless Ethernet Repeater (24VAC input) with 1 meter outdoor Ethernet cable, wall-mount and pole-mount brackets (2 antennas not included) $2,400 S3100-BR-49 Outdoor 4.9 GHz wireless Ethernet bridge (24V AC input) with two 25-meter outdoor Ethernet cable, wall-mount and pole-mount brackets (2 antennas not included) $3,325 S3100-BR-5x Outdoor 5.3 / 5.8 GHz wireless Ethernet bridge (24V AC input) with two 25-meter outdoor Ethernet cable, wallmount and pole-mount brackets (2 antennas not included) $2,500 S3100-BR-24 Outdoor 2.4 GHz wireless Ethernet bridge (24V AC input) with two 25-meter outdoor Ethernet cable, wall-mount and pole-mount brackets (2 antennas not included) $2,500 ANT-WP8-24/S 8.5dBi gain, 2.4GHz band, 65° beamwidth, patch antenna with 1 meter (3-foot) SMA-SMA cable $99 ANT-WP16-24/S 16dBi gain, 2.4GHz band, 27° beamwidth, patch antenna with 1 meter (3-foot) SMA-N cable $200 ANT-WP13-49-5x/S 13 dBi gain, 4.9-5.85 GHz band, 40° beamwidth, patch antenna SMA/F connector for use with S3100 $200 ANT-WS16-5x/S 16dBi gain, 5.25-5.85GHz band, 90° beamwidth, sector panel antenna with 1 meter (3-foot) SMA-N cable $1,000 ANT-WP18-5x/S 18dBi gain, 5.25-5.85GHz band, 18° beamwidth, patch antenna with 1 meter (3-foot) SMA-N cable $410 ANT-WP24-5x/S 24dBi gain, 5.25-5.85GHz band, 9° beamwidth, patch antenna with 1 meter (3-foot) SMA-N cable $550 ANT-WP25-49 ANTENNA; 25dBi; Linear, Flat-panel; 4.9GHz-5.1GHz; 6deg H-BW; N-Type female; ROHS $600 ANT-WP18-49 ANTENNA; 18dBi; Linear, Flat-panel; 4.9GHz-5.1GHz; 20deg H-BW; N-Type female; ROHS $250 ECAB-25 25 meter (82 foot) outdoor Ethernet replacement cable $90 ECAB-50 50 meter (164 foot) outdoor Ethernet replacement cable $100 Warranty: Includes a 2-year standard hardware warranty.
For cheap, simple line of site video Microtek minilink works well.
Tried it at a couple of sites and nothing but problems - Videocomm!
