I have an older wired motion detector in my home that the sensor light is always on and will not allow me to secure that zone. Why does the sensor stay lit constantly, it never used to? Is this unit bad? Thanks
Wired Ademco motion detector problem
Jan 29, 2008
Most relevant reply
Maybe. You didn't say what type of motion detector it is; I'll assume it's a passive infrared. Take a piece of cardboard and tape it over the front window of the detector. If the red light goes out, then the unit is seeing something in the room it interprets as motion. For…
Yup. Sounds like its relay is stuck. Just replace it.
It could be. Have you checked your connections? If voltage falls below a certain point on most motions, the unit will "open". The most common cause for a drop in voltage is loose or bad connections (sometimes from corrosion).
I could see that if the zone was held hopen but what about the light?
Take a piece of cardboard and tape it over the front window of the detector. If the red light goes out, then the unit is seeing something in the room it interprets as motion. For example, hot air blowing right on the unit. If the light stays on even with the cardboard in place, open up the unit and look for bugs or anything else that shouldn't be there. If there's no obvious explanation and the light is still on, replace it.
