Lynx battery replacement in motion detector?
Feb 01, 2007 9 Replies
EyeBee
go ahead and replace the battery. nothing will change as a result. except for the low battery alert.
Greetings,
recently my Ademco Lynx woke me up by beeping in the middle of the night to tell me the batteries are running low in my wireless motion detector. I've had this happen a few times in the wireless smoke detector, and it's quite easy to replace the batteries in that one -- it takes two 9- volt batteries. I opened the cover on the motion detector, and the panel downstairs immediatly started making a rapid beeping sound -- I did a + off and it silenced it, I assume this is some sort of tamper alarm? So basically what I want to know is, when I remove the battery (it's a small little 3-volt I believe, had to find it at Radio Shack), is it going to mess anything up as far as the motion detector is concerned? I recall when it was installed, the installer said something about setting up the motion detector so that our cat wouldn't accidently set it off, so I'm wondering if these settings are stored in the motion detector, and will removing the battery reset it?
Thanks for any help, Chris
both batteries?
Thanks for the answers! My only concern is, that I don't know the installer code.. let's hope I don't need to use it!
Chris
You won't need it for battery replacement.
You wont need it just do code+ off and then code+off again.
Ah, that explains it.
