Solution 862
Oct 07, 2006 4 Replies
Jump to replies (4)
Solution 862 open original image
Hi
i have a solution 862 alarm with a wireless receiver and key fobs and wireless pirs.
the system was all working ok except i didnot know the master code to add new pirs and fobs. i have all the manuals for it and for the life of me i cannot work out how to code the system to acknowledge the snesors and fobs.
i have set location 427 to 8 = re005 installed location 424 to 12 = 8+4 for horn/strobe indication for radio arm/disarm
i have the solution vireless interface we800 connected correctly as it was working before.
So how do i tell the alarm panel that i have wirelss pir sensors? How do i configer the fobs?
the book says enter mastercode 1 # usercode from 9-16 # then prss the transmitter button and the systme will acknowledge this.
any help would be great.
if they are wireless PIRs you need a ESN (electronic Serial Number) programmed into the panel for each
Dana
Thanks, I have the serial no for each device. Are you able to tell me how to programme the sol 862 to acknowledge these pirs. Do you know the exact coding sequence as the instuction manual does not have this in it?
Thanks
Dana Wiegner wrote:
Look at this forum. It talks about your issue.
cheers jerry
thanks
but this is my issue which i posted
MJD wrote:
