Re: 832 power trouble - low batt. error again.
Dec 01, 2005 0 Replies
ooops sorry... thought nobody answered this guy
What do you mean continuously? Does the low battery restore and then fault > again?
> Old building? What's the electricity like? I wonder if the panel maybe
> doesn't have enough
> to work with and can't keep the batteries above the 11.8V (or whatever) > threshold
> > have a power 832 system that I worked on a eight months ago. The
> > system worked fine for 3 months then gave a low battery error
> > continuously. I changed the battery thinking the battery might have
> > gone bad (old battery). That didn't solve the problem. I had heard
> > of the bridge going bad on 832's and giving that error falsely. I
> > had them order a new board and I replaced it yesterday. The error went > >
> > away. Today I checked in to make sure everything was good and the
> > trouble light was on again. I checked it and sure enough it said
> > "Low Battery". I have tried two batteries and two boards now. The
> > non-profit that I am helping with this can't really afford to keep
> > buying parts. Anyone know what might be causing this mess? They have
> > a dial in module, printer module, and autodialer all on the system.
> > Might the devices be drawing too much power from the system ? Someone
> > recommended a bigger battery, but I wouldn't think that would solve it
> > since the power is not going out. This happens when the system is
> > plugged in and no power event have occured. Thanks all.
