Outdoor Motion Sensor Recommendation
Oct 08, 2005 3 Replies
Jump to replies (3)
try those..
dg85 are very stable even in very cold situation..
"JW" a écrit dans le message de news: mZR1f.1346$ snipped-for-privacy@newssvr21.news.prodigy.com...
I need to replace a couple and can't seem to decide due to all the choices available. One in for my carport covered rear driveway, 26' W x 40'L, and the other is for the front entry sidewalk. I guess I just need to know which brands you guys feel are reliable and cost effective due to the wide variety of units. I can't see a difference between a 120.00 unit and one costing 30.00. Thanks, Joe
Try the Optex VX-402 (
) or the Paradox DG-85 (
) .... Both detectors are made to be mounted outdoors, cheaper models are not for outdoor use....... Regards, Russ
