need help: 2006 econoline wiring
Jun 23, 2006 3 Replies
Jump to replies (3)
hi,
would appreciate a clue :)
can someone point me to the physical location of the factory keyless entry system control module on my 2006 Econoline Van (lowtop conversion package)
thanks in advance
Pj
It's located somewhere between the front bumper and the rear. ;-)
Kidding! You should try the automotive stereo groups (rec.audio.car). I'm pretty sure someone there will narrow down the location for you. Good luck!
Thanks for the tip J
Ciao
Ventura
alarman wrote:
