DSC Security System - Can it unlock a door?
Nov 29, 2005 0 Replies
Good evening,
I am looking at instaling a DSC security system in my new house. I was reading through one of the manuals and it talked about unlocking doors. I am taking a shot at it, but I think this would be done with the system using the 7503H connected to a rely that is connected to a electric door strike. ( I added the relay because I am not sure what voltage the output is.) Am I close on that? If that is how it is done What do you program that as? I can see that I would use the PGM and then activate with the *71-4, but what PGM do you use?
I see in the Escort manual that I would want to program it with a "Programmed Pulse when Active."
Ok, so am I close here? Any advice? Any good websites that talk about this?
Thanks, Doug
