Door Switches/ where buy ?
Nov 24, 2009 27 Replies
Most relevant reply
Robert L Bass
There's a product from GE Security called a 3005 "Roller Plunger" contact which is probably the closest to what you have in terms of size, shape and function. I sell them online. So does almost every other online alarm store. Here's a link to the SR-3005 on my website: the hole…
Door Switches/  where buy ? open original image
I have a hard wired, simple, Radio Shack alarm system. It uses small spring-button switches that go into the frame of a door jamb. You drill a hole about 3/4 of an inch or so, and install the switch in the hole.
Radio Shack no longer makes alarm systems, and thus they don't sell the switches. Can anyone recommend a place to buy them please ?
Thanks for any advice on this.
James
Radio Shack never made alarm systems
What I see a lot of now are magnetic reed switch type door contacts, I bet those would be easier to find than a pin switch. Pretty standard security stuff.
nate
Look for a *real* electronics store in your area. Not a big box or chain store, but a privately owned ma and pa shop.
re: "Radio Shack no longer makes alarm systems"
Radio Shack never made anything...they just sell stuff (and junk) with their name on it.
What city do you live in, that there still is such a thing as a ma and pa electronics shop? I haven't seen anything like that in about 25 years. All the ones I shopped at as a kid either went belly up, or morphed into something else, and none have the rows of racks and back room full of parts like they used to. An independent alarm equipment dealer could fix OP right up, if they are willing to sell retail.
Or look online- that is what actually replaced small local jobbers. Graingers, Digikey, or similar, probably carries it. MPJA.com is a good place to start, if you don't need commercial grade stuff.
-- aem sends...
-- aem sends...
Here are a couple:
Take a look at
and see if any of them fit your needs.
Don
ADI might be better if he has one nearby and they aren't all uptight about commercial only sales (like my local Grainger)
nate
Wow, Don, that link shows my exact switch configuration, but it is now a reed switch, which will be an improvement !!!
Thanks Don, and for all the other replies !!
And yes, Radio Shack did sell alarm systems, I have two to prove it, but of course I don't need to.....
James
I have come across a Radio Shack branded alarm, though I wouldn't call it a security system. Whether radio shack "made" them or not isn't really the point, they do exist . I think the reason you see so few mechanical plungers is they a far less reliable than magnetic reed switches.
Instead of sinking for money into this alarm , you may want to consider upgrading to cowbells hung from your doorknobs.
re: "And yes, Radio Shack did sell alarm systems"
I don't believe anyone said RS didn't *sell* alarm systems.
Some (even I) said they didn't *make* them, in response to the words in your OP:
"Radio Shack no longer *makes* alarm systems..."
re:"What city do you live in, that there still is such a thing as a ma and pa electronics shop?"
Western NY, on the shores of one of our Great Lakes.
Never saw a ma, but there's definitely a pa - more than one in fact.
Rows of racks, a back room full of parts, and they'll order individual parts if they don't have 'em in stock.
Maybe the OP could find such a store by searching here:
If the hole in the woodwork is too shallow for the 3005 you can use the "short" version of the same switch, called a 3008:
You can buy basic sensors and switches at electrical supply houses around here - not all of 'em, but some...
You can get different types of plunger switches from Lee Electric or any electrical supply house that carries theirs or equivalent products. The recessed closet door switches can be obtained with either normally open or normally closed contacts. You can print out a picture and show it to a salesman at any electrical supply company and they'll know what you are looking for. You need to specify open or closed contacts for when the door is open. Lee Electric has a catalog in PDF format that you can download that will show you the specs and pictures of the different switches.
TDD
All Electronics on line has all kinds of switches.
Thanks you for the post.
safehouse brand?
