Car remote's range becomes smaller
Dec 29, 2005 11 Replies
Jump to replies (11)
Hi
I have a car with a remote lock. Over a period of several years it seems that the range becomes smaller and smaller. Right now I need to be within few feet from the car for it to work.
I've replaced the battery. What else might be happening?
TIA, Eugene
press the transmitter to your chin when you push the button, you'll get a few more feet of range.
you been watching "everybody Loves Raymond " too much. :)
heheee...yah. but seriously it works, I get abt 15ft more range...also depends on if I shave or not. It's the Belgian method of extending cellular phone range.
That won't cause dain bramage like using a cell phone will it? ;)
Move or extend the receiver antenna. When you cleaned the carpet you moved it. Move it away from the steering wheel. it's under the dash.
only if you're n ot wearing your tin foil helmet
Did you test the new battery? If yes, did you test it under load conditions (with a proper battery tester)?
Finally, is the new battery seated properly? Are the contacts bent, dirty, oxidized?
Beachcomber
there is 2 possibility here, the receiver part of the alarm is untuned or the transmitter is untuned..
if you have no prior experience with such manipulation,don't come back here saying that you broke everything,and its my fault,those manipulation could ruin the remote or the receiver...
if you open the transmitter you maybe able to see some small pot or some adjustment,take in note where are the actual adjustment (with a notch on the board with a marker where the wipe of the pot is before touching it) and try to adjust ONE pot at a time,also look for soldering joint that could have failed,especially in the antenna section of the remote..
if that doesn't work,its the receiver,and you need to do the same on it.. AGAIN,if you have no prior experience with such manipulation,don't come back here saying that you broke everything,and its my fault....
if you choose not to do it,you could figure out if its the receiver or the remote by trying a new remote on it...
by the way some alarm manufacturer will give 5 year warranty on such device,take a look at there web site to know if its still under warranty..
"E. F." a écrit dans le message de news: snipped-for-privacy@g43g2000cwa.googlegroups.com...
I finally found a spare remote unit and tried it. It worked from the distance just fine. So it seems that the receiver is OK.
