Ademco Vista-10SE Chime does not chime
Jul 02, 2007 4 Replies
Jump to replies (4)
I have a Ademco Vista-10SE unit where everything works perfectly from the alpha keypads, but when i set the unit to Chime (sound on door open without alarm), it does not chime - even though the display shows that the door has been opened.
Is "Chime" displayed in the keypad?
Is something else opened on that zone? - if there's something else on that loop that's opened the door's not gonna chime.
Is "Chime" displayed in the keypad? - Yes it is.
Is something else opened on that zone? - Chime shows up in the keypad, and when i open a door the keypad shows that the door (including zone #) is opened - but no sound.
Thanks for taking time to ask about the problem.
Ok...but is ANYTHING else on the same zone with that door? For instance if there are 6 windows and that door on zone 3, and one of those windows is left opened the DOOR will not chime.
Does ANYTHING else chime?
| > Is something else opened on that zone? - if there's something else on that | > loop that's opened the door's not gonna chime. | >
Is the zone programmed as an entry/exit or perimeter?
Enter your code, then "test" If it beeps then, its probably a programming error
