Wireless intercom recommendations for Senior Care Home please
Apr 24, 2006 1 Replies
I'm looking for a wireless intercom system that will be used for an Senior care facility. It has to contain one base and 6 wireless stations, to be installed in 6 separate rooms, and the base has to be able to communicate with each of the 6 units separatly, and when need be all units at the same time.
It would be nice if the intercom would have a light that lights up for the specific room that is calling the intercom that way, we'll know which room is calling. Please let me know if you know of something that meets our needs.
Thanks
Luke
Before you commit to wireless, I have a question. Is there by any chance a drop ceiling in the facility? If there is, you can easily run a wired system. Wired intercoms tend to be more robust and less expensive.
I don't have personal experience with a wireless intercom system that has all of the features you've requested, whereas there are several wired systems we carry that would easily fill the bill. Aiphone is one of the better known makes of commercial grade intercoms. Their NEM-10/C system is intended for use in nursing and assisted living facilities. It can handle up to 10 substations (patient room units), provides "all call" paging and private, individual communications with individual rooms.
If wiring is completely out of the question you might take a look at Rauland-Borg's offering. It's called "Responder IV Nurse Call". It claims to do all you've asked but it also looks expensive.
