self calibrating clock via wifi?
Mar 31, 2011 4 Replies
marcus hall
The Best Buy chumby is sometimes on sale for ~$50. It uses ntp to set the time (and can do much more). marcus hall
I have some atomic clocks that are not working because apparently the clock signal is too weak at my apartment.
Since I have a wifi router in my apartment, I wonder if there is any clock that calibrates itself via internet and is wifi enabled?
I can use a PC or a tablet computer to do this, but I'm looking for something cheaper (under $50).
marcus hall snipped-for-privacy@tuells.org
You might be able to add a better antenna and preamp to your existing radio clocks. Do you know what frequency they use? Preamps are available with ~20DB gain from DC to 1GHz and can be cascaded to give even more gain.
Typical "atomic" clocks receive WWVB at 60 KHz, so noise is the primary issue. Adding a preamp would just amplify the noise right along with the signal. Florescent lighting, switching power supplies, and, ironically, noisy wifi routers are common causes of the interference. An external antenna might help, but there is not usually anywhere to connect it on the clock.
Turn the darn thing onto a wall at 90 degrees?
Run a wire from outside to the backside of the clock or other side of the wall? Just bring in a stronger signal to the clock with osme wire or aluminum tape painted. Try a thin piece of wire along the wall and under the clock...pull it tight so it cannot be seen without staring or run some aluminum duct tape on the wall and pint it to match wall colour.
Take it outside and see if the signal is strong enough in the area, at all, first.
