opinions on GRAFIK Eye system by lutron
Mar 02, 2005 4 Replies
Jump to replies (4)
I am starting finnalize the building of my home, I am looking at installing the lutron grafik eye system for lighting control. Can I get some options on the system:
Does it work well. Is there better products for the price. What whole home control system does it work with. I was hoping to put one pc on each floor that would have an application like meedio to control all aspects of the home.
Thanks in advance. Cliff
I use a 3106 w/ my home theater and it works great. You have two options for controlling it. Via IR or RS232. They are a bit pricey but very solid in both performance and reliability. Watch E-bay or some of the Home Theater classifieds to pick one up at less than retail.
Thanks,
I have just got the quote a bit high. What is the best quality powerbased lighting control system out there ?. ( I mean x10 type product ) Control over power lines.
I am leaning towards smarthome.. but I am in canada and don't feel like paying taxes and freight any canadian companies with the same product line.?
PnP
Cliff -
If you are looking to do whole-home control, GRAFIK Eye is probably not the best solution. I would look at RadioRA instead. GRAFIK Eye is intended to be more of a room control, not whole-home. Although it will work, functionality-wise, I think you'd be happier with RadioRA.
As far as purchasing it, there are tons of distributors in Canada that carry it, so you shouldn't have any type of shipping or taxes to deal with
Charlie
C Hirsch wrote:
Instead of X-10, have you considered the newer Z-wave products?
