modify MC10A
Sep 10, 2009 4 Replies
Jump to replies (4)
Try this website:
There's a 110V->220V mod for the MiniController but the instructions may or may not match your particular circuit board version.
Ok, I know, but it is another model.., and doesn=B4t work. Thanks
Generically, there are 2 ways to do this. The first is where you change the capacitors / resistors / MOVs in the original to new values; but, if you dont have the schematic, or want to fiddle with the insides, give this a miss.
The second procedure involves no mods to the original. use a 230- to-110 volts step-down transformer. Make sure its a transformer, NOT a triac / SCR based adapter. These transformers are actually autotransformers (single centre tapped winding), and its a simple matter to add a 0.1 uF capacitor to jump the signal to the "other" side.
Its all there on Ido's site; its just not very easy to find, or give the direct URL on account of the frames. Anyway, its also replicated at
Hope this helps. If you need any more information, just ask!
Regards,
Anand Dhuru
snipped-for-privacy@gmail.com
I don=B4t the schematic for this model..:(
I know this system
Lnik very interesting:)
Regards jjlcubas
