Lynx-R and X-10 Options
Aug 26, 2006 3 Replies
Jump to replies (3)
Lynx-R and X-10 Options open original image
I have a Lynx-R Wireless Keypad and would like to control via X10 two lights at two different locations in my home. Can someone recommend an X10 device to use with this keypad?
You will need the following:
- Ademco 1332X10 Transformer
- X-10 Phase Coupler/Blocker
- up to eight X-10 switches/relays
Frank can I use two of these devices instead of the Phase Coupler/Blocker:
Or would I have to use this device:
Here's another 220v Dryer Coupler, which I don't have.
Please note my dryer is Gas and it plugs into a 110 outlet using a three prong plug. Therefore, I'm not sure how the secound unit would work.
Both of those units are for 220 volt dryer outlets (3 prong is old style, 4 prong is newer version). Many homes have a 220 volt outlet by the dryer even if they have gas so the homeowner can use either a gas or electric model. However, many with gas do not. There are wire-in versions of those devices for those that don't have the dryer outlet.
Jack wrote:
