Insteon Users note re: KeypadLinc setup - Installation status update
May 13, 2006 7 Replies
Jump to replies (7)
The Insteon KeypadLinc comes configured as a 6 button device but can be converted to an 8 button device with the included faceplate kit. The instructions then say to pull the setup tab all the way out (airgap), wait 10 seconds then press it while holding in keys A & H. That won't work so looking at the Users Manual (not the included Quick Start guide) they tell you to do the same thing but don't press the setup button all the way in - just press it gently to the "neutral" position (my words). That doesn't do it either. Through trial and error I learned that there is one more step - you must keep pressing A & H for at least 10 seconds till the A button starts to flash. That little tidbit would have saved me 20 minutes tonight!
Another note, if you're planning on doing some cross-linking it is helpful to have an assistant and a pair of walkie-talkies. To crosslink you have to hit the paddle on one unit for 10 seconds, go to the other unit and press that one for ten seconds. Press it again for 10 seconds and go back to the first one and press that one for 10 more seconds. More locations mean more running around so an assistant can be REAL helpful in a larger home.
I currently have almost half of my X10 stuff replaced with Insteon and expect to finish the job over the next week. I'm at the point where Insteon reliability has improved to about 95% and X10 has dropped below
50%. While Insteon can handle both, the two protocols do NOT play well together. Before I started the conversion X10 was at about 98% with some unsolvable troublespots and getting progressively worse. The Insteon problems I'm having now are not related to the protocol as much as they are to timing issues with the translator. Once RoZetta replaces the translator I expect to see most of those issues resolved.
The biggest thing is the mental conversion of how Insteon works vs. X10. We are used to receivers and transmitters where any device that sends the proper code will work. With Insteon, every single unit is two way and has it's own unique address (think MAC address). Only units that have been programmed to pay attention to each other will work together. There are a number of pluses and minuses to this approach and it certainly takes some getting used to!
Bruce,
I had no problems turning my KeyPadLinc to 8 button mode. Both methods listed in the QuickStart and the Manual worked for me (just tried it, too). There's no need to hold the buttons down until linking mode is activated. The fiddly part is the set button is easy to release or bounce while you're trying to pull it out or push it in. I prefer the Manual version (pushing set button to neutral position), because when the button LEDs power on (after about 2 seconds) you know it is done.
For linking, there is multi-link mode which saves time if you're going to link stuff by hand. However, if you're halfway serious you should get PowerHome (free 30 day trial, enough to get all your links setup), although it does not have a particularly good interface it is BY FAR the best program for Insteon linking.
There is also GroupCommander, which is a freeware linking program (a little harder to use because it can't discover existing switches and links).
BTW, an important thing is you should factory default your switches before you start programming for real use. The switches sometimes come programmed with non-existent links from SmartHome during QA testing. (A cool feature of PowerHome is that it can also defragment the link databases in the switches).
Thanks for that info. I may have had a finicky Keypadlinc because I tried every other way possible. I didn't realize that PowerHome could do the things you describe. I'm going to get a copy right now. Sounds like it will make a huge difference! Where can I find Group Commander?
Answered my own question and found Group Commander and some others. PowerHome looks like the best option so far. Thanks again for turning me on to these.
Maybe I'm being dense but I can't figure out how to get PowerHome to discover my Insteon devices and the manual says nothing about it (that I could find). Any pointers will be much appreciated.
Look for the "phinsteon.rtf" doc in the directory where you installed PowerHome. This doc tells you the basics....yes, more detail is needed, but it is not there yet.
Has anyone had any success with setting their links (and their 2414 ser controller) up with PoweHome and then moving the controller over to the Elk M1?
I know the M1 has to have the lights set up in order....but if the order is the same as you set up in PowerHome, can the M1 now take advantage of the links that just got cleaned up with PowerHome?
BINGO! That's exactly what I was looking for. I'll study it and play around with the program today.
