ActiveHome Pro Macro operation
Jun 12, 2005 0 Replies
Have x10 Activehome pro and tried to set up my first macro. The macro works fine when its run automatically and when you click on it via software but will not trigger using a controller although you can see the macro activate on the screen. Controller(s) will work the modules just not the macro. Anyone please have any ideas, documentation provides little assistance Thanks Wink
