Wireless Security
Jan 28, 2006 2 Replies
I have set up a wireless router in my office for visiting clients.
If I set up security with WEP do I need to give each client a password?
Use WPA-PSK and you will have to give them the pass-key. The wireless device should be in your DMZ, not on your LAN, since they are using unmanaged PC's.
Better use WPA. WEP is unsecure. If you're using WPA-PSK, then you'll have one key for all clients.
Yours, VB.
