Weird Loss of Connectivity Issue -- Help?
Dec 03, 2005 10 Replies
degrub
"ndeed, I can't even connect to my Linksys Gateway via browser." unplug the cable and start there. Hard reset the cable gateway. reconfigure. THen work your way out.
I'm on a cable connection, running through a Linksys Cable Gateway.
I cannot connect to the Internet via web browser, but can connect in every other way (ping, Usenet, E-mail, etc....).
But here's the rub: I use a Cisco VPN client to connect to my office servers. When the VPN client is installed on my machine (no vpn connection initiated, just the client installed) I can usually browse normally. If I lose my browsing ability, initiating a VPN connection restores it, and keeps it restored for some time AFTER I drop the VPN connection.
If I uninstall the Cisco VPN client, I lose all browser connectivity (but all other connectivity remains fine).
It's not a DNS problem, because I can't reach sites via straight IP. Indeed, I can't even connect to my Linksys Gateway via browser.
Any ideas would be appreciated.
Thanks, Kyle
what is ipconfig /all telling you ?
Kyle Stedman wrote:
Hi Degrub,
If you don't mind, could you e-mail me at kyle snipped-for-privacy@yahoo.com?
Don't want to post IPCONFIG info here. Thanks,
Kyle
degrub wrote in news:Kkikf.2814$ snipped-for-privacy@newssvr19.news.prodigy.com:
Why, do you think your ip address 67.86.174.188 is a secret.
If worried about your lan, you should be using 192.168.x.x which will not route accross the internet.
Bit Twister wrote in news: snipped-for-privacy@wb.home.invalid:
Come on, give me a break! I'm new at this :)
Windows IP Configuration
Host Name . . . . . . . . . . . . : gateway-whatever
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . : bleep, bleep, bleeped
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.0.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 167.206.3.231
167.206.3.165 167.206.3.234
Lease Obtained. . . . . . . . . . : Saturday, December 03, 2005
2:40:24 PM
Lease Expires . . . . . . . . . . : Saturday, December 03, 2005
3:40:24 PM
i am assuming the VPN has a 1 hr time-out/refresh ? Otherwise looks normal to me.
Didn't mean for you to post the ipconfig data. just to look at it and make sure you were getting services from the expected places.
One other thing to look at - try removing and then installing a browser
- opera, netscape, etc. It looks like that is what has gotten confused and is using the wrong net connection.
Kyle Stedman wrote:
Just to be sure it's not a DNS issue try browsing somebody by IP, for example yahoo at http://68.142.226.38/. (ping yahoo.com first and browse the resultant IP if you don't want to click my hyperlink.)
I'm betting it's not though, since you can't browse to your linksys which you undoubtably hit via IP not FQDN.
So, assuming it's not just a baffed up linksys as another poster suggested (hint, try your pc on somebody else's network first) than your TCP/IP stack is probably corrupt. You need to uninstall and reinstall it, which isn't especially easy but isn't exceedingly hard. A corrupt winsock will blow up
32 bit apps but simple stuff like ftp, ping and telnet will still work.
Your best bet as a somewhat novice might be a utility for it like
. Otherwise it involves browsing your registry, deleting the winsock and winsock 32 keys from hkeylocalmachine/software, unchecking TCP/IP from one of your adaptors, saving and rebooting. Then manually add TCP/IP back in, but don't pick it from the list, say "have disk" and browse to c:\\windows\\inf for it. This will cause it to reload the files and hopefully fix the problem.
Your VPN working might be because it uses a different TCP/IP stack that's customized to deal with split tunneling issues rather than the stock one that's used for normal connections.
-Russ.
Thanks!
I tried it all, and now, some 4 hours later, I've reintalled my OS and all is working fine.
I think it was some corruption in the TCP/IP stack, where my browsers couldn't switch between the default connection and vpn connection. Lose the VPN connection...lose the ability to just browse.
Thanks again, Kyle
degrub wrote in news:K6qkf.2743$4o7.2501 @newssvr24.news.prodigy.net:
"Somebody." wrote in news:4wrkf.4485$ snipped-for-privacy@nnrp.ca.mci.com!nnrp1.uunet.ca:
Thanks!
Thanks again, Kyle
Re-installing your OS is a bit of a "sledgehammer to kill the spider" approach, but the spider is dead nonetheless.
Glad you got sorted out.
-Russ.
