VPN pass-through with NetScreen 5 (ScreenOS 5.0.x)
Jul 28, 2006 1 Replies
i am looking for a way to pass some VPN traffic (PPTP) through a NetScreen 5 configured in NAT/Router mode to an external VPN server. I craeted a trust to untrust security policy containing the necessary ports and protocols (TCP/1723 and GRE) but this does not work. I was told it depends from the ScreenOS version. Has someone a working config or another example?
also i tried IPSec/L2TP, which didn't work either probably due to the NAT. i heard about the possibility do tell the NetScreen to pass the IPSec-packets through. So together with a NAT-T capable VPN-server it should be working to. Any hints?
thanks in advance matthias
Your post just isn't clear and you don't say what ScreenOS you're running or what you're trying to talk to. I think the docs above should help.
alan
