Netscreen with PXE
Oct 27, 2005 0 Replies
People,
I hope you can help me.
I've got a Netscreen 25 up and running, and got DHCP Relay Agent working across the DMZ Trust interface. I now need to get devices in the DMZ working using PXE boot to a server in the Trust Network segment. This does not appear to work. If you're interested, the devices are Wyse 9000 Series thin clients - I'm trying to flash upgrade them from a Wyse Rapport Server in the Trust Zone, and this requires then to use PXE.
I've been through the PDF's for ScreenOS 5.0 but PXE isn't mentioned at all. Does the NetScreen / ScreenOS 5.0 not support relaying of PXE requests / responses?
BTS, the setup works if I move the devices onto the Trust segment.
Regards
Ken Z
