Transparent mode in NS 5GT (Port mode Extended)
Apr 27, 2006 2 Replies
Most relevant reply
Fer
In port mode EXTENDED, transparent mode is not possible:
I have a 5GT with port mode in EXTENDED: Trust, DMZ and Untrust.
I'm trying to configure in Transparent Mode.
I clear all ip interfaces ( Ethernet 1, 2 and 3) : set interface ethernet1 ip 0.0.0.0/0 I assigned an ip to VLAN1: set interface vlan1 ip 10.200.1.1/24
But, I try to assign ethernet1 to the zone v1-trust, or ethernet3 to v1-untrust....but dont=B4t work.
When i put "set ip interface ethernet1 zone ? ", only i can change to trust Zone. No option to V1-Trust
When i put Port mode in "Trust - Untrust" works fine in transparent mode.
I test in my 5gt with versions OSScreen : 5.3.0r3.0(new) and 5.0.0 (old)...
Somebody Knows if there is some type of special configuration in EXTENDED Port Mode?
Thanks!
You should ask support about that one, that sounds like either bug or a limitation that I've never run into.
-Russ.
