spyware
Feb 26, 2005 4 Replies
Jump to replies (4)
Hi, who can tell me where to get spyware knowledge or help.Thanks.
Just like to add, use these free tools too.
Spywareblaster.
Spybot Search and Destroy
Many places.
This tool will help you with adware/spyware and other problems.
the log here.
you need further help use one of these forums
Also visit these
PCs infested with Adware/Spyware are often also full of viruses and other malware. If you don't have a virus scanner and don't want to spend money on one then use
't forget to download updates for all of the above products. They are no use without the updates.
Stop using Internet Explorer and use an alternative such as
Jason
Oh, yea, and read up on what a Host file is and what you can do with it.
