Block instant messaging with Pix 7?
Jan 28, 2006 5 Replies
Nicholas DePetrillo
I recently installed 7.04 and I noticed it has "inspection engines" that allow for layer 4-7 inspection. So it should come with some facility to detect and block popular instant messaging protocols via application layer 7 inspection. Check the PIX 7.04 ASDM docs, it should…
I upgraded my Cisco Pix 515 to OS version 7.04 a while ago because Cisco has all sorts of marketing up on their site claiming that it can block instant messaging.
Well, I've found a lot of marketing material on their site, but I haven't been able to find any actual documentation on how to do it. Does anyone have experience with this? It would be much appreciated.
Thanks, Marc
7 inspection. Check the PIX 7.04 ASDM docs, it should mention something.
You could always just block the ports some popular instant messaging services run on. Here is a list of a few:
AIM
5190 - 5193
MSN Messenger (Including Voice)
6901, 6891-6900
Yahoo
5050
You can find more on Google.
Pretty sure all those services will fall back to port 80 if you block those ports. One trick we used to do before we had firewalls that could identify that traffic regardless of port, was to permit them but rate limit them to such a degree that they're useless for practical puposes. By permitting them you prevent the fallback to alternate ports but at 1kbps, when mulitple users hit the service it's almost completely useless.
-Russ.
That's a good point, they are sneaky.
I haven't checked my PIX ASDM yet but I am sure that the inspection engine/layer 4-7 inspection usage is in the documentation for the PIX. It should not be that hard to get going.
After much searching, I found the "port-misuse" command in the Cisco Security Appliance Command Reference 7.0.4.
When you're in http-map configuration mode, enter:
port-misuse im drop log
This will prevent Yahoo Messenger, AIM, and MSN from hiding their packets in HTTP traffic, but can really impair performance on the Pix.
Which is all great... but unless there's some other global way to check packets, I'll still need to block several ranges of ports, and not be certain that this will work.
Marc Teale
Correction - that command should be:
"port-misuse im action drop"
