I'm trying to forward port 800 from the net to a local ip in my network. i can't seem to connect at all even though the local pc is running the server looking on port 800 and the sonicwall seems to be set up properly.
I've got in the sonicwall network a rule set up to forward and it seems everything is set proper. I'm running the TZ150 with SonicOS standard
3.0.0.0.23s
i go like this.
1: firewall
2: firewall rules
3: add
4: action allow, always, service port 800 special rule i created
5: source wan, destination wan, source * lan 192.168.168.7 both fields start and stop
6: doesn't work even tho the server ip is .7 and it is static plus the server is running and looking on port 800.
it is Kerio email server.
can connect fine to the kero email server locally.
