PIX 535: port forwarding newb problem
Mar 05, 2006 1 Replies
Hi folks, I need some help.
Trying to setup port forwarding for an app. for the first time on a
535:
I need to port forward a DMZ subnet on int dmz_v904 (eth3), forwarding all ports >1023 to host A.A.A.A to port 60199 on inside int (eth1).
e.g.
name A.A.A.A server
object-group network vpn-pool description *** VPN dial client pool addresses *** network-object B.B.B.B 255.x.x.x object-group service Tivoli tcp port-object eq 60199
*********THIS IS WHERE I NEED HELP****************
access-list dmz_v904 permit tcp object-group vpn-pool host A.A.A.A gt
1023 access-list inside permit tcp host aansso1tmra00 object-group vpn-pool object-group Tivoli
is my syntax correct? and what else must I do?
All help very much appreciated.
Think I've sorted the problem with the help from a friend.
Was told I only need to apply one rule to the source interface, as below:
access-list dmz_v904 permit tcp object-group vpn-pool host A.A.A.A eq
60199
This should forward all permitted source subnet traffic on TCP 60199 to the destination A.A.A.A server on the inside interface.
