Repeated attempts to 4662 tcp/udp
Mar 23, 2005 3 Replies
Jump to replies (3)
hi there, yesterday I wanted to experiment something with iptables, so I set up my cisco soho 77 to become transparent and route all inbound traffic to a pc on my lan, 10.10.10.33 . So I opened Amule and tried to connect to a server, then shut down it in about two minutes (just to analyze some packet). Amule was set to 4662 TCP/UDP to have a highid (active connection) however, it's about three hours that I've shut down the application, and I see a load of packets dropped, in linux with iptables and in windows. here's an extract from windows firewall:
2005-03-23 07:56:30 DROP UDP 81.36.209.69 10.10.10.33 4672 4662 55 - -
- - - - - RECEIVE
2005-03-23 07:56:31 DROP UDP 62.117.11.252 10.10.10.33 4672 4662 63 -
- - - - - - RECEIVE
2005-03-23 07:56:32 DROP TCP 83.165.67.76 10.10.10.33 2614 4662 48 S
2199089281 0 16384 - - - RECEIVE
2005-03-23 07:56:34 DROP UDP 80.236.55.185 10.10.10.33 4672 4662 63 -
- - - - - - RECEIVE
2005-03-23 07:56:35 DROP UDP 80.14.54.72 10.10.10.33 4672 4662 63 - -
- - - - - RECEIVE
2005-03-23 07:56:38 DROP TCP 83.165.67.76 10.10.10.33 2614 4662 48 S
2005-03-23 07:56:40 DROP UDP 82.225.20.30 10.10.10.33 5672 4662 63 - -
- - - - - RECEIVE
2005-03-23 07:56:40 DROP UDP 80.130.209.195 10.10.10.33 4672 4662 63 -
- - - - - - RECEIVE
2005-03-23 07:56:41 DROP UDP 61.144.196.191 10.10.10.33 58958 4662 63
- - - - - - - RECEIVE
2005-03-23 07:56:41 DROP UDP 83.135.74.17 10.10.10.33 65293 4662 55 -
- - - - - - RECEIVE
2005-03-23 07:56:43 DROP UDP 84.4.124.219 10.10.10.33 4672 4662 55 - -
- - - - - RECEIVE
2005-03-23 07:56:44 DROP UDP 81.38.223.77 10.10.10.33 4672 4662 55 - -
- - - - - RECEIVE
2005-03-23 07:56:47 DROP UDP 62.179.76.3 10.10.10.33 4672 4662 55 - -
- - - - - RECEIVE
2005-03-23 07:56:49 DROP UDP 82.231.32.163 10.10.10.33 4672 4662 55 -
- - - - - - RECEIVE
2005-03-23 07:56:52 DROP UDP 218.28.104.9 10.10.10.33 4672 4662 63 - -
- - - - - RECEIVE
2005-03-23 07:56:52 DROP UDP 82.64.143.82 10.10.10.33 4672 4662 63 - -
- - - - - RECEIVE
The funny thing is that *mule uses per default tcp/4662 - udp/4672, I've changed this value in preferences (tcp-udp/4662 same port), and as we can see packets arrive on udp 4662, as my choice.
I'm wondering why I still receive those packets, *mule applications are not running from hours, do you have any explanations? There aren't any machines active on my internal network than mine.
Thanks
Just a guess but I assume since you did run it for a few hours there are still servers looking back at your IP address still expecting it to be sharing files. After a bit it will die down again. My son runs a Bittorrent client downloading anime movies. Even with his computer down for a while my router still logs hits on the appropriate TCP ports. Guess this is the same thing.
eMule/aMule use all this ports: 4661/tcp 4662/tcp 4672/udp 4665/udp
4711/tcp 4242/tcp
I took it from a page on how to configure a firewall to use eMule, but my experience trying just the opposite, stop it, it's that it uses even more ports.
Regards.
I reconnected to the server, removed my share, disconnected and every attempts stopped.
funny
