Opening TCP & UDP ports???
Dec 01, 2004 1 Replies
jch
Make sure you know your PC's IP address (eg 192.168.1.100). Enter that into the WRT54G admin page in the Applications and Gaming page. For WinMX enter port 6699 TCP and port 6257 BOTH and click Enable. Then hit Save Settings. I'm not familiar with limewire.
I am having trouble with my file sharing software (winmx, limewire) and I'm running on WinXP and use a Linksys Wireless G router. Every time I test my ports for file sharing the test fails. It says that there is no TCP port for incoming connections and no UDP port for incoming or outgoing packets. How can I fix this? I could really use someone's help. Thank you.
