OutPost configuration
Jul 23, 2006 5 Replies
Jump to replies (5)
Hallo, at Win XP platform I have Apache and mySQL only for testing sql and PHP. How to set OutPost, to local work for localhost? -> Only localhost for Apahe, without outside addres? I don't know how set "only localhost"! -could you help mi? Thx
What about setting Apache and MySQL to localhost first?
You're running a host-based packet filter, you'd absolutely know.
This is a "not having read the documentation" problem rather than a firewall problem. RTFM. Both Apache and MySQL can be configured to listen on localhost only.
Superseded for clarification of which documentation I was referring to.
cu
59cobalt
Ok, ok... maybe I don't know about it..?...mayby I'm beginner....
That's why you're supposed read the documentation to begin with.
cu
59cobalt
in the apache.conf, change the LISTEN to read LISTEN 127.0.0.1
