OT: Bios problems; any ideas on "fixing"?
Mar 09, 2007 1 Replies
For some reason my computer would not recognize my cd roms, so I pressed F2 and went into the bios window. I went to the area that showed the CD roms and hit Reset default. And I have screwed things up big time. No matter what i do, I cannot get back into that window. I have held down f2, f8, f10, delete, and other keys when booting up and nothing. However, when I hit f2 after a few seonds I get 2 icons on a screen that use to have about 50 and nothing else will happen. How can I get back into the bios and once there, what should I do to get it back where it was before I screwed things up? I am at the library and will return on Friday to check if anyone has responded. I have done all I could think of and would appreciate any help you can give me.
----------------------------------------------------------------------------------------------------- Since I posted the above, someone came over and got windows to go back to normal, but the computer will still not allow access to the bios window. I even took the battery out of the motherboard for about 10 minutes. Is that enough time or should I do something else?
Thanks in advance for your help. Dickie
Thanks!
Sometimes there is a jumper on the motherboard that resets BIOS back to defaults, I would not recommend this if the computer is important, but if you need the devices then it is probably a must. As far as the CD rom issues go, if they are SCSI or IDE I would check connectors and power and see in bios if the channel is actually disabled. try and tell us what happens
