NIS 2005 on a gateway/router pc?
Jan 15, 2005 0 Replies
Would it be possible to run norton internet security 2005 on a pc that would be used as a router/gateway? What I would like to know specifically is if anyone knows if NIS would be able to use its own parental control and firewall rules for the internet and local lan pcs. So it would be set up to block or allow web sites and newsgroups requested from the lan. So if someone on pc1 is trying to access a newsgroup that is blocked it is denied. or same for a newsgroup or whatever.
i am wondering if it can even do that like you set up NIS on the pc router and then apply to the lan nic and internet nic the rules.
