I have a Netscreen 5GT and have been able to connect to the web admin interface (unencrypted http). However when I try it with HTTPS (port 443) it doesn't work. What is causing this? Don't tell me they're forcing me to install a valid SSL certificate before letting me access it via HTTPS?
Netscreen admin can't use HTTPS?
Feb 27, 2005
Only in 5.1 have they supplied a built in certificate, but if you're running older ScreenOS, you'll have to put in your own certificate. It doesn't have to be 'valid' or a cert from a trusted CA, but you have to have one loaded, self signed or otherwise. Consider upgrading toβ¦
Read the full replyOnly in 5.1 have they supplied a built in certificate, but if you're running older ScreenOS, you'll have to put in your own certificate. It doesn't have to be 'valid' or a cert from a trusted CA, but you have to have one loaded, self signed or otherwise. Consider upgrading to 5.1 if you haven't already.
I went here and selected the Netscreen 5GT, but it says there's no software to be updated:
How do I create a self-signed certificate? I'm having problems with this. I generated an RSA 1024 local certificate request. What am I supposed to do next to get it to appear as a local certificate? All I want to do is enable SSL access to my managerment ui.
