Linux and firewalls
Nov 22, 2004 21 Replies
Yep, that pretty much describes it. I want something that will install without problems. Like Duane said, if I have to go out of my way too much to install it, then it probably won't wind up on my machine.
That pretty much describes my experiences with XP. :)
If you want to try an easier to install version of Debian, check out Mepis. It is the first Debian based distro that I have seen that correctly detected and configured all of the hardware on my old Thinkpad.
It isn't that you are spoiled, it is just that you ventured into unfamiliar territory and felt uncomfortable about being out of your environment. I will grant you that Debian doesn't have a reputation for being a newbie friendly installation, but their installer is getting better. .
