kerio uninstalation probs
Jan 30, 2006 1 Replies
how do u manualy uninstal kerio personal firewall as i have removed all the related files and reg keys that the website told me to remove but every time i try to reinstal i get the following message; the configuration data for this product is corrupt is there any way to reinstall without it checking for existing copies or any way around this prob.
Only way is to remove all traces of the previous install from your HD and registry. Make sure you've killed the Kerio folder under Program Files, and search the registry for "Kerio" and see what's left there. If you get everything it should reinstall cleanly.
