Hi. I have two servers : A: running SBS2003 (active directory + dns + dhcp). 1 NIC. Static IP :
192.168.1.2 B: running Server 2003 Standard (file server + IIS). 1 NIC. Static IP :
192.168.1.3
and a 3com router/ADSL modem which connects us to internet. (Static LAN IP : 192.168.1.1 and Dynamic WAN IP).
TrendMicro Officescan is installed on both and Enterprise Client Firewall is also enabled.
With this setting, I can only VPN to A and dont have any access to B. But if I disable the firewall on both, everything is fine. Does any one know if any special policy should be enforced to make officescan firewall vpn friendly?
Hamed
