Firewalled torrents behind two routers?
Mar 12, 2007 1 Replies
die.spam
what port range did you open? what torrent client are you using.. have you enabled UPnP in your torrent client? Flamer.
I have a Speedtouch 510v4 and have added a Linksys WRT54GS to it. I've put all the ethernet cables into the Linksys so the wireless laptop can see any shared files. All that works great but now when I get a torrent on the go it says firewalled? I've opened the port already on the Speedtouch (10.0.0.5) and have also opened a port on the Linksys (192.168.1.102).
What now?
I've tried changing the IP's so that they are the same (ie
192.168.x.x) on the routers and have tried turning dhcp off on one or the other computer and every time i do that it screws the whole thing up and takes hours to get it reset and back to square one.
Help please....
Flamer.
