Filewall Alert on Bla Trojan Horse?
Jan 28, 2005 5 Replies
Terry
I'd like to add that it seemed like the traffic was from my computer to my computer (same IP address). Is this a false alarm or is there a trojan horse program running on my machine? Thanks! Terry
Filewall Alert on Bla Trojan Horse? open original image
I have Symantec Firewall running on a WinXP Pro workstation with Service Pack 2. Just got this alert message and not sure what it meant.
Alert message:
Rule "Default Block Bla Trojan horse" blocked (COMPUTER (xx.xx.xx.xxx),1042). Inbound UDP packet. Local address,service is (localhost,1042). Remote address,service is (COMPUTER(xx.xx.xx.xxx),1042). Process name is "N/A".
I did a complete virus scan using Norton AntiVirus and it didn't find anything. I ran SpyBot also and the machine was clean. Should I be concerned about this alert? What might have caused this flag?
Thanks in advance for your help!
Terry
Thanks!
Terry
*blocked*
Why worry about it?
Duane :)
Terry wrote in news: snipped-for-privacy@news.tc.umn.edu:
I doubt it and most likely it's false. However, you can look around for yourself with the tools in the link to make a determination.
Duane :)
Not to worry. I've seen this also on my system with NPF 2003. Here's a link to Symantec's Knowledge Base that details how to make a rule for the application that's using the same port as the Bla Trojan without interfering with blocking the actual trojan:
Terry confessed in news: snipped-for-privacy@news.tc.umn.edu:
A false alarm. No doubt a windows process acking RPC data.
That's the problem with these little monitors--they report normal activity malware they blocked and give nubees a false sense of security.
Run a full scan if you're worried. Also, get yourself one of these free plugin scanners like Adware SE if you don't have one.
-- ipgrunt
